I did a swap with the Noctua PWM fan on an NX3000 and I agree that the air flow is reduced. I believe that is a big reason it makes less noise. I have built and overclocked many gaming computers and have used a lot of different fans. I found the biggest difference in sound is the speed and airflow. Not so much the brand or rubber buffers or high tech bearings. Although I did pay up for the Noctua.Sorry to dig this up, but I just put 2 of the Noctua PWM fans into my NX6000D and it feels like there's significantly less airflow out of the front of the amp. Is that normal? I hooked them up properly splicing the yellow fan wire to the red amp wire, and the black to black. They're definitely running, and they're basically silent, but it seems like they're not pushing as much air as the stock fans. When I was sitting in front of the amp, I could feel the air from the original fans, but now with the new fans I can only barely feel it if I press my hand up against the grill.
Yeah, for HT use the stock fans are serious overkill imo.I did a swap with the Noctua PWM fan on an NX3000 and I agree that the air flow is reduced. I believe that is a big reason it makes less noise. I have built and overclocked many gaming computers and have used a lot of different fans. I found the biggest difference in sound is the speed and airflow. Not so much the brand or rubber buffers or high tech bearings. Although I did pay up for the Noctua.
Less speed is less sound. I think the stock fan was overkill for in home use. It think the airflow with the Noctua is enough for most users. I hope anyway.
You can do either method with noctua fans, see my posts on the prior page. I’ve done a few with butt splices and a few with cutting down the plug. I copied smcmillan2’s method and cut down the pwm 4-wire pin to 2-wire size. Works like a charm and it’s the method I’ll be using going forward. I posted a pic on the prior page.am I reading this thread correctly as
1. nocturnas splice into the wiring
2. arctic is plug and play? I saw 1 or 2 references but am wondering if I missed something. Seems like plug and play would be ideal, although not hard to butt splice two wires.
I'm getting ready to order for a nx3000, nx6000 and a nx4-6000
Yup, same everything just times two. I used these in my 6000d'sanybody do this on a 6000d? there's two fans I believe. same steps? same fans or different?
The 5V fans will run at full speed when the unit kicks on. It starts by supplying around 5-6V I think. If the thermal load increases, it will kick it up to 12V. At that point, 5V fans will probably bite the dust from receiving 12V.Thanks for the response.
I'm a little confused. When I look at the information Noctua provides on Amazon both the 12v and 5v fans are exactly the same in terms of performance. If you scroll down on the link below to the product description part of the page you see the following.
The 5v 4 pin PWM fan has a RPM of 2200 and an acoustical noise level of 17.7 dB(A)
The 12v 4 pin PWM fan has a RPM of 2200 and an acoustical noise level of 17.7 dB(A)
I don't mind trying the 12v fans but there doesn't seem much point spending another £28.00 if Noctua say the RPM and noise specs are the same.
Cheers
?? No no no.Thanks for the response.
Cheers
