Im having a hard time deciding on which setup to go with. I currently have di-poles (300's) and floor standing speakers (450's) on order for my surround from av123. Im considering going with the bookshelf's in the back instead because i dont really have room to sit a floor standing speaker. Only problem with this is i really dont like having the huge speaker (rs250) hanging from ceiling or wall. Another option is to cancel the towers and go with dipoles only in the back. Im going to be about 70% movies and 30% music. Whats your guys opinion? I will be wiring for both situations so either way i will be ok if i change my mind. Just really a matter of what to keep ordered. If i decide to go with the dipole's only i do have a set of x-ls that i could use instead later on for rears. I will be treating the room acoustically so that might affect the performance of the di-poles a bit. My room is going to be right at 17ft to screen when finished so i will have little room to play with in the back.
di-pole
http://img90.imageshack.us/my.php?image=directzq8.jpg
Direct/di-pole
http://img171.imageshack.us/my.php?i...tdipoleks1.jpg
di-pole
Direct/di-pole
