Ditto on the
CM 4221 . It is a small antenna that should work well for your channels at that distance. Attic install should be fine unless you have a metal roof.
If your coaxial cable is old, consider replacing it too. Use good quality RG6, never the cheaper RG59, which has too much loss.
