I currently have a coax running directly from my roof mounted antenna directly to my Samsung T-150 OTA HD box. Since I currently only have one HD set-up this works fine.
I am now going to add a second HD set in the basement and will want to run the antenna feed to two places. What are my options?
I am assuming I could cut the current coax and run it through a splitter so that it goes to both locations correct?
My other question is, I have the Direct-TV running through a multi-switch that has an "antenna in" connection. Can I run the existing coax to the multi-switch antenna in and then use splitters (diplexers?) to break the signal out at each TV set? I am assuming I can do this but, want to make sure that splitting the signal back out does not cause any problems with the HD OTA signals.
Thanks for any help.
JT
JT
