Status
Not open for further replies.
1 - 3 of 3 Posts
· Registered
Has anyone ever grounded and indoor antenna ? I have the Radio Shack Bow Tie Antenna, and it needs to be grounded at times to receive certain stations. I need to hold it for a half minute to make it ground and give it enough signal strength. Is it possible to put a ground on an indoor antenna ? If so, how can you do it ?
Any help would be appreciated.
Scott G.
· Registered
Simplest method would be to ground it to your A/V receiver's chassis ground or phono ground, since no TV I've seen has a ground connection that's easily accessible. Next easiest would be to attach a ground wire to the ground pin on a standard A/C plug and plug it into the same power outlet that your system is on.
Some interesting info is available at Rane Electronics' web site: http://www.rane.com/library.html#tech
Â*Â*Â*Â*Â*|>
Â*Â*Â*Â*Â*|\\
Â*Â*Â*Â*/|Â*\\
Â*Â*Â*/Â*|__\\
Â*Â*/__|____
Â*Â*\\_ ___ _ \\
Jon Gauthier
"If I'm not sailing I'd rather be watching sailing in HD!" - Me
1 - 3 of 3 Posts
Status
