Here is the email response from ReplayTV:
Begin:
Hi ReplayTV Customer,
Thank you for being a ReplayTV customer.
Description/Question:
After last nights call my local antenna channels are gone. I live in zip
code 78749. I've tried to re-setup the system by changing the antenna
input and then changing it back with no luck. I tried zip code 78735 and
nothing is bringing back my local antenna channels. Jeff
Resolution:
We have a server problem nationwide that is interfering with the download
of antenna channels. I have the same problem here on my Replay at tech
support. Hopefully by Monday the problem will be fixed. I would suggest
that you plug your antenna directly into the TV until we can get this
resolved. Thank you for your patience.
If you have any additional questions, please refer to ReplayTV's Online
Customer Care page at
www.replaytv.com or feel free to contact us by phone
at your convenience.
Best Regards,
David
Customer Care
ReplayTV, Inc.
www.replaytv.com
ReplayTV. Some televisions have all the fun.
1-800-933-5899
END
Cheers
ReplayTV -- The only one that had firewire...
