Originally Posted by aviman33 /forum/post/0
I think I'll build it oriented in one direction and point it at the weakest signal as you suggested. Most all of my signals are between 9 and 30 miles, do you think that would require an amplifier? Zip is 17033.
You have a complicated situation. For starters, you have WHP-DT CBS 21 broadcasting on VHF 4 and WHTM-DT ABC 27 on VHF 10. The DB-2, DB-4 or CM 4221 are not going to work for the CBS station on low VHF 4. However, WHP-DT will be switching it's digital signal to UHF 21 after the analog shutdown in 2009 while WHTM-DT ABC station will stay on VHF 10.
Since you live in hilly country, I plugged in an antenna height of 600' under the antennaweb.org options to get a more complete list of digital stations. I removed the color codes in the list, as you need to enter your exact location into antennaweb (using a height of 100' or so) or tvfool.com to get a better feel for what stations you can get.
uhf WGCB-DT 30.1 IND RED LION PA 184° 25.8 30
uhf WLYH-DT 15.1 CW LANCASTER PA 106° 9.5 23
vhf WHP-DT 21.1 CBS HARRISBURG PA 303° 12.8 4
vhf WHTM-DT 27.1 ABC HARRISBURG PA 291° 16.3 10
uhf WITF-DT 33.3 PBS HARRISBURG PA 303° 12.7 36
uhf WGAL-DT 8.1 NBC LANCASTER PA 186° 16.7 58
uhf WPMT-DT 43.1 FOX YORK PA 183° 17.3 47
The bottom line is that you have two digital VHF stations. Your stations are grouped in 3 different directions: 106, 183-186, 291- 303 degrees. Tricky. Are you looking at an rooftop or attic mount?
