Hi,
I tried researching but I see that Antennas are based on particular circumstances.
I plan on mountain the Antenna on the roof which is 38' above ground level and the towers are +/- 4miles away
Here is a link to the TV Fool Report http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id=f1f07e5dfabbd3
The installer I spoke with said he normally would use a Radio Shack Mid range antenna for something so close.
based on the report it says an indoor set top antenna should be sufficient but I have tried one or two and get nothing. I have a few tall buildings near me which may account for the indoor antenna not working
So if anyone could recommend a decent outdoor antenna that picks up both UHF and VHF for my situation I would appreciate it.
The cable run is going to be at least 60' to the basement then up to 4 TV's over three floors from there so I may need n amplifier or an amplified antenna
Thanks in advance - looking forward to enjoying guilt free HDTV for years to come.
