Antennas Direct DB8 UHF HDTV Antenna
1406 Views 1 Reply 2 Participants Last post by  texasbrit
I'm in the market for a long range antenna and I wanted to know what kind of signal you guys and gals are pulling in with the Antennas Direct DB8 UHF HDTV Antenna.
1 - 2 of 2 Posts
It's an impossible question to answer. You need to sort out which type of antenna you NEED, based on where the transmitters are, what's the terrain like between you and the stations, are they VHF or UHF (and are they moving back to VHF in 2009) and so on. Post here http://www.avsforum.com/avs-vb/showt...81623&page=218 with your zip code and you'll get some real help.
But just FYI - the DB8 is OK but is not the best UHF antenna, and does not receive VHF-hi. The CM4228 is a similar design but has some VHF-hi pickup, and is less expensive than the DB8. The CM4228 and the 91XG are generally thought of as being the two best generally-available UHF antennas, but you would not use either of them for fringe VHF.
1 - 2 of 2 Posts
