2981 - 3000 of 5179 Posts
Ah gotya! I took yor "Mute" mode as sarcasm for shut downs so that was a missunderstanding on my side.
About the graphs I think ARC is doin heavy treatment to get yor sound in line. I don't exactly recall the app screens, but shouldn't there be a post ARC indicator?
Since the fronts show same characteristics the bumpy graph might be not only room related. In case you want to get back that kind of sound flavour you could limit the EQ max to where the subwoofer integration is handled. But are you missin sth in the sound at the moment? What are you aming for?
About the "Mute" mode, it's a bug where the receiver goes into a complete mute state, which is only resolved my factory to hard resetting the receiver and setup the receiver from scratz again. It's seems to be a bug with the CEC controlls.
About the graphs i forgot to run the calculation. I have uploaded them again :p
Hi guys, I'm thinking of adding an ending to my Anthem 510, I thought 'advance Acoustic XA-160 I find that here in Italy to less than 1000 € .Siccome I have little experience with the finals, I wonder if it would be a good expenditure and if sfrutterei the most of my Paradigm Monitor speakers 11.Nei next few days i will go to my dealer to do a ascolto.This Advance is a good ending or have other advise me that do not exceed the € 1,000?
Thank you
Ouch - how's the weather in Italy lately? Tough bet to tell what is available in Italy for that price at the moment. :confused:
Why not asking the dealers at your hands about what amplifiers they can offer for less than 1k€ and then ask in forums what ppl think about those...
There is no MRX specific amps either, the MRX will try to get the best out of any amp or speaker combination you come up with....
...hope you find a good ending in the finals though:rolleyes:
I actually am very satisfied with how it sounds Anthem is in my ht that with the music, but as I read more of the parties that a final could further improve things then I'm really curious to see if this change will sarà.Deciderò to purchase only if after listening known abysmal differences, otherwise not worth the pena.In alternative on € 1,000 over the Advance Acoustic xa-160 my dealer has these models:
Used Meridian 557 to 1350 €
Bryston 3b st used at 1100 €
Forte Audio Model 6 used € 990
Naim Nap 175 v € 990 ex demo
Rotel RB-1552 MKII 760 € new
Unison Research Unico upower € 1390 new
amplificato ergo sum
I actually am very satisfied with how it sounds Anthem is in my ht ... after listening known abysmal differences...
I'd go with the Rotel, but thats a personal exp. If the MRX doesn't get hot the way you regularly use it - then save the pena for Magdalena:D that's what I would do...
Though I spoke of the used Bryston as possibly having remaining warranty in "that other forum"...Rotel makes solid and reliable amps that tend to offer good value. I have an older 1095 that I really like.
You guys are geniuses! :) I tried increasing the room gain by 2 dB and it made all the difference - I was floored both by how easy it was to adjust (just hit calculate and re-upload) and the profound effect it had. It was EXACTLY what I was looking for - a lot more of what I call "sound energy" in the lower frequencies. 2 dB was great, though a scene or two still didn't have all the "oomph" I've become accustomed to in the Denon (such as the elevator shaft section doors opening in Tron: Legacy when the elevator is in free-fall). I then tried 3 dB, but that seems like too much. I'm confident I can find a happy middle ground in there with more experimenting.
There is now no question that the Anthem MRX-510 is a superior AVR to my old Denon 3808ci in terms of sound quality. It would appear, however, that the Anthem has more trouble with HDMI handshaking (it frequently "flips out" with alternating snow static and green/magenta screens when going back to the root menu in Tron and selecting a scene to play) but it eventually figures it out in 5 - 10 seconds.
So, a big thank you to you gentlemen for your help. VERY much appreciated.
chances are this is a cable issue and not so much an issue with the anthem. I have not had any handshake issues since adding the mrx510 to my system.
It's possible that the Anthem is more sensitive to cable quality, but I've been using the same cables for several years with the Denon and have had no issues.
Adding Cooling Fans with USB
I need your advise. My MRX-510 is turning off playing at big volumes. I think this is because of the overheat protection. I want to put on the upper cover a 5V USB cooling fan like used for laptops (Deepcool N17 Super slim Laptop cooler).
Is it possible to power it by the USB port on the rear panel of MRX-510??? Very much appreciated
I need your advise.
I doubt such a cooler would make the difference. The amp section is cooled via the tunnel and vent. Make sure the built in fan can easily blow out the hot air and is not blocked. If that doesn't work i'd rather consider an add. amp instead. I dont know about the USB port but its intended for mem sticks only, unlikely to power a big fan ...;)
Hello ..
Am very impressed with the SQ of the Anthem 710.
Apologize if this as been already covered. Have been searching within the thread and can't find any specific information related to the 710 offering a 2 channel analogue pass through ...
I understand that Anthem offered this feature as an improvement or enhancement from the previous generation MRX ...?
Is this (pass through) 2 channel audio without being digitized by ARC accomplished by the set up of the configuration (listening config) ?
Carrying the above thought further it appears the configuration acts as a listening preset ?
For the same source (OPPO BDP 93) I bitstream over HDMI setup, and have analogue bypass if the second configuration is setup to turn ARC off.
Did Anthem offer a work around for users looking to use the DAC of a source player vs, I believe what is an ad hoc workaround in the use of zone2 ? (no processing). I suppose one could use the zone2 as a preset ...
Am i way of the idea on this ?
Quote:Originally Posted by grasshoppers
Quote:Originally Posted by luismanrara
I recently heard about these receivers and even though they do not have analog inputs I'm still quite interested in these units, particularly the 710.
Do the units have any analog pass through, or are even the analog inputs digitized?
No analog pass thru, analog inputs are digitized in the MRX.
ARC will have a larger impact on what you hear vs a pure analog input...it's that good.
Audition one if you can.
Not correct. Unlike the original MRX units, the new units DO offer Analog passthrough -- unprocessed, Stereo Analog output -- only Volume control. However, as stated, they only have Stereo Analog inputs.
Processed Analog output is also available for these Stereo Analog inputs. This would include ARC of course, and also Surround Sound processing (generating audio for Center and the Surrounds).
Audio Processing can be engaged separately for each Input you define which uses Stereo Analog audio input. If Analog input Audio Processing is engaged, there are separate settings in the Input definition to engage ARC and/or Dolby Volume.
--Bob
Page 59... post#1745. don't know if that answers your question? Hope it helps.
Thanks for your reply, mazpri. I thought about additional amps. I would be the best solution. Unfortunately it is too expensive for me now.
I read on forums that guys were using laptop cooling fan powered by USB with Pioneer and Denon receivers. But on MRX-510's rear panel the USB is marked as 5V/500mA USB update. If it is sufficient to power the cooling fan, I need to know.
... is marked as 5V/500mA ....
ah, thanks for figurin that out, so now you know all you need to ask in notebook-forums for a cooling solution you can waste your money on. ;)
But if you have the money for a 510 and a speaker setup to max it out i would think there is more to find for buyin a simple 2ch amp...
Thank you grasshoppers, this is indeed the same post I was looking for, ideal.
Bob does very good work as well. I have seen many of your posts throughout this tread, well done.
So, is Bob saying that yes analogue passthrough is achieved by turning ARC off ? And this can be done via configuration within the menu settings. I will try this soon...
I have ahead the 710 for few months now. With Autumn approaching, time to trial this MRX, she's a beauty.
...Thank you grasshoppers, this is indeed the same post I was looking for, ideal. ...
I also recommend to read the manual available for download on Anthems website. Chpt 3.6 is about input settings and how it works - so its a good read. It almost covers everyting one needs to know in one or another chapter and i didn't find any missinformation yet - just take it word for word. It did answer most if not all questions i had
I have another question and not sure if this is an Anthem MRX-510 issue or what. I have a Sony BDP-S5100 Blu-ray player that I use for SACD's as well. I had it hooked up with my MRX-300 and it played the SACD just fine via HDMI but it will not play audio with the 510. Not sure if I have a wrong setting with the 510 but it is hooked up via HDMI 1 just like the 300. The 300 had no issues playing the SACD but the 510 will not.
Any set up issues or anyone have an idea?
Ted
Did you ever solve his issue? I have the same problem with a S5100 and a MRX 710.
MRX x10 can't do anything with the DSD signal found on SACDs. I think the x00 handled DSD. You have to setup your SACD player to convert DSD. Settings name could be a lot of things, but "convert to PCM" is the most likely. Before you ask, this is not lossless, but won't cause audible differences (and x00 converts DSD to PCM for itself, as does most of the amps, so you really won't lose anything).
Additionally, cooling is kinda up and running, I would say currently half of the air goes around the MRX and not through it, and the heat-tunnel fan is not yet operational (yea a lot to do), but unit is already cooler than when it was running in the open. Fans are inaudible. I must say it turned out to be very good.
anyone using a lumagen mini with their receiver by chance? if so what setting are u using to pass thru video to the lumagen..
Hey Barnahadnagy-
What fans are you running? I remember there was a model you wanted that ended up being out of stock. Also, what are you using as a power source for the fan(s)...Curious regarding the USB as a power source on the Anthem, as well as potential interference caused by a 12 volt transformers in many fan set ups. Also like that your fans are "inaudible"...not the case with my two "Coolerguys" 12 cm fans....looking for a better option for a future upgrade.
