Proper couch: while I am an engineer, I am not an electrical engineer. And while I am an A/V hobbyist and even enthusiast, I am not an expert.
I've had some trouble with my Denon x4400h. I've done a lot of troubleshooting on it, which I have documented over on the "official Denon 2017" thread, which I will not bore you with. The end result has been that I've convinced myself (and at least one person on that thread I consider to be more wise on such matters than I am) that my Denon has taken some sort of hardware (amplifier) failure.
One thing I learned as part of my troubleshooting was that only two of the 11 pre-outs can be "fully disconnected" from the internal amps of the receiver, such that limits/struggles with the internal amp can influence the signal that goes out the pre-amp? (Source:
"OFFICIAL" 2017 Denon "S-Series" /...)
I have a "difficult to drive" center channel which is basically a bookshelf speaker turned on it's side. It's an Ascend Acoustics "center-oriented" Sierra 2EX, with an in-room sensitivity of 86 dB/Wm.
I also have the Ascend Sierra Tower left-right's, with the matching RAAL ribbon tweeter upgrade. These are a much more sensitive 92 dB/Wm. I love them.
My system rounds out with a pair of Ascend HTM-200SE bookshelf rears that are in-between those two extremes (89 dB/Wm), but with poorer low-end performance that often measures a cross-over into my needed at 90 Hz, rather than the more desireable 80 Hz.
Early in my troubleshooting efforts, I purchased a Marantz MM7055 5-channel external amplifier, that's supposed to be a superior power source than the Denon I was struggling with. It's rated to 140 wpc, 2-channels driven, into 8 ohms with 0.08% THD. I believe Audioholics measured capability to provide 108 wpc into all 5 channels (at 8 ohms), which I believe is considerably more capability than the Denon x4400h.
So when I run Audyssey it measures the need for a really big (+6 to +7.5 dB) trim boost on the center channel speaker, and I guess that's not unexpected when the in-room sensitivies the manufacturer reports are 6 dB different... and adding the Marantz external amp wasn't able to help me... the guys over on the Denon thread explained to me that only the Front Left-Right pre-outs can be completely disconnected from the internal amplifiers, so if the center channel amp in the denon is struggling, running the pre-out won't avoid the signal clip.
I'm hoping to get a new receiver that can take greater advantage of the Marantz external amp, rather than getting a new center channel speaker and new home theater furniture ("tv stand"), as the piece I'm currently using has high WAF (even though I'd love to get rid of it...).
