So I'm really tempted to buy a new set of front speakers to replace my current ones. And then I was wondering if I could us my current front speakers for something so I started to read on different forums; And sure, there are those that say there are cons using Towers are surround speakers but the majority do however agree that: If you can replace all the speakers, have the space and know how to set it up its worth it.
So now I am wondering if it would be in this case: I've attached a picture of my layout. Alternative 1 shows how it is now, the surroundspeakers (Side and rear) are not towers. Its a 7.1 system
Alternative 2: My front speakers are replaced by the new ones, my old towers are moved back between my surround speakers.
Alternative 3: The side surround is moved back together with the rear surround and used as a rear surround. The tower takes over the job as side surround completely.
Which one would would be the best? If any? Or should I invest in something else?
