Status
Not open for further replies.
1 - 5 of 5 Posts
I was wondering if there was any difference in sound quality when passing a digital signal using a mini plug or a dedicated coax/optical output on a sound card?
I have heard both and preferred the dedicated coax/optical output to the mini plug output, but I didn't do a direct comparison so my ears may have decived me!
Any preferences here on which sounds better?
For DD / DTS it shouldn't matter, as these are sent as packets of data, they either make it or they don't. For PCM (CD's, computer .wav's etc) it could make a difference as the clock the DAC uses is part of the signal (search for jitter).
A good coax or optical should have an edge over the mini-plug as the mini-plug isn't impedeance matched to the 75 Ohm SPDIF standard and could introduce noise or timing errors.
â€For DD / DTS it shouldn't matter, as these are sent as packets of data, they either make it or they don't. For PCM (CD's, computer .wav's etc) it could make a difference as the clock the DAC uses is part of the signal (search for jitter).â€
Actually both DD/DTS and PCM are sent as packets over S/PDIF and the DAC clock is derived from the S/PDIF for both.
The difference is PCM is linear and DD/DTS is compressed requiring a side-track through a decoder before the resulting PCM is mated with the incoming S/PDIF clock at the DAC.
Discussion Starter · #4 ·
Sorry I am a bit flustered, my brain isn't working full speed tonight;)
So would there be any noticeable difference between the two outputs with either of the signals?
â€So would there be any noticeable difference between the two outputs with either of the signals?â€
A properly designed Coax/optical circuit should provide better audio quality that the typical miniplug connector.
1 - 5 of 5 Posts
Status
