Status
Not open for further replies.
1 - 3 of 3 Posts
apparently there's a tree blocking my view of the 119 satellite.. i may be able to get the 110 one, but i may not be able to get HDTV over directv. i live in the NY area, and apparently the satellite is very low on the horizon, so i may be screwed.
the installer is working now working with putting a tripod on the roof, but he still thinks it will only help me get the 110, very low optimism for the 119 bird.. any suggestions?? this sucks.
Chainsaw is my first thought. Also, don't believe these people who tell you that you can have only a short length of cable: Maybe you can move the dish someplace else and avoid the folliage. I used a detached garage location chosen by a casual dumb luck when I started this business.
You might want to get another dish if there is another location on your property where you can get a good view of the 110 sat. It is convenient to get both sats with 1 dish but you can also use 2 separate dishes located in different locations.
1 - 3 of 3 Posts
Status
