1 - 4 of 4 Posts
· Registered
Specifically, what I mean is running 2 HDMI cables and the tv power cord through the wall behind the tv to an outlet near the floor. This is for a remote hunting cabin under construction so there won't be any building codes to worry about with the power cord...just don't want to cause issues with the HDMI.
· Registered
Don't think there will be a problem, but you won't want to tightly bundle the wires together. Keep them as separated as possible wherever they run parallel. You might run them on opposite studs if possible.
· Registered
Discussion Starter · #3 ·
All 3 cables will all be fed through 2" plastic conduit pipe that's already installed in the wall..but won't be tied together. I figured that modern power/video cables were shielded enough that it wouldn't cause any issues, but I wasn't for sure..
· Registered
Shielding is relatively ineffective against high-energy, low-frequency fields, so it's a good idea not to run power and signal cabling in close association. It sounds, though, like you're only going a few feet; if that's so, you'll probably be all right.
Kurt
Blue Jeans Cable
1 - 4 of 4 Posts
