Just checking before I purchase wire.
I have 1 inch snurf tubing to front and rear..................I'm thinking rather than pulling two separate runs of inwall Cl3 rated 12 AWG 2 conductor wire it would be much easier to pull one 4 Conductor 12 AWG run. I have four 90 degree turns to navigate and am not looking forward to it. Breaking out the lube!
All wiring is for four subs powered by two Peavey ipr2 7500's. My only concern is heat with both wires being next to each other while sustaining 2000 watts at short intervals..................just wondering if signal will be degraded in any way.
Thanks for feedback..............
