Status
Not open for further replies.
1 - 3 of 3 Posts
hi! i have an hd receiver, 2 directv tivo receivers, and comcast cable.
i used to have cable/directv on the same wire and used a diplexer but when i added hd , the multiswitch did not have antenna in. what multiswitch would anyone recommend? tks
Premium Member
You need a cascadable 5x. A 5x8 is probably your best bet. The two most often mentioned here are featured at http://www.solidsignal.com/satellite/ but it's usually good to do a little investigation on your own. All brands seem to work well.
1 - 3 of 3 Posts
Status
