I've read a few threads comparing single vs dual subs, but nothing comparing single vs duals that are the same total price.
Also nothing specifically on two HSU VTF-2 MK5s vs a single VTF-15H MK2.
If the loss in lower frequencies for a single listening positioned outweighed by something that the dual subs offer? I've also heard that there can be negatives of dual subs, like cancellation in the 70-90 Hz range.
Also, why is it that the VTF-2 MK5 reaches down to 16 Hz with one port open while the larger VTF-3 MK5 HP only goes down to 17 Hz?
Another oddity - when I overlay the VTF-2 MK5's frequency response chart for 1 port open over either the VTF3 or VTF15H in similar setup, the smaller sub seems to have a flatter curve and produces more db at lower frequencies. How can that be? I must be reading the chart incorrectly right?
You can click on the first chart for each subwoofer below in separate browser tabs and then click between the tabs to compare differences:
VTF-2 MK5 Subwoofer
VTF-3 MK5 HP Subwoofer
VTF-15H MK2 Subwoofer
My room is a concrete floored basement that is L-shaped. Both legs of the L are about 12-13 ft wide and 30 or 24 ft long. Mostly 8 foot ceilings.
VTF-2 MK5 Subwoofer
