Status
Not open for further replies.
1 - 8 of 8 Posts
I have Comcast Digital Cable with HDTV. I was just wondering if it were possible to combine OTA HD antenna with the Comcast digital cable box? It is a Scientific Atlanta 3100HD.
In other words, is there a way to pass a signal from an OTA antenna into the HD Cable box, and switch to that input.
I'm seriously doubting it, but just though IF there was a way, someone here would surely know.
_Tim
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
No.
Discussion Starter · #3 ·
Thanks (again), Ken!
-Tim
Banned
No, the cable box can't decode OTA HD broadcasts - they use a different modulation scheme (8VSB) whereas SA cable boxes use QAM, they are incompatible. You would need to buy a separate OTA HD STB to receive OTA from an antenna and feed both STBs into the HDTV. Complain to Comcast to carry all the local HD channels.
Discussion Starter · #5 ·
Thanks for the extended explanation. They have all except PBS and CBS. Everyone knows about the CBS situation, but I expect PBS *very* soon. Discovery is supposedly around the corner too.
Just out of curiousity ... now much do OTA HD STB's run?
Super Moderator
I've seen open-box OTA-only deals in the $250-$300 range (got one of those, myself). It goes up from there. See the STB sticky at the top of the forum for makes, models and what not. Then take the model numbers and hit google or one of the shopping bots.
Doc
They're getting a lot cheaper; I regularly see brand new ones from reputable eBay sellers for well under $300 these days. Just goes to show that the retail markup on these things is huge.
I've seen the Samsung OTA box for as little as $310 from real stores, as well...
If you buy a STB online, make sure the site has a liberal return policy, in case the box doesn't meet your expectations.
Many online retailers don't allow returns, or they charge huge restocking fees.
1 - 8 of 8 Posts
Status
