Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
Originally posted by leeler Mikeyboy, I'm in the process of doing the low level format now. I'm unsure of how to do this exactly so I removed the hard drive and sent it along to someone to do it for me. I hope to have it back this weekend. I also decided to add a fan while I have it open. Hopefully this will cure it. I'll post back here once I know for sure. |
Originally posted by drmckenzie Mikeyboy, Just to clarify: My 100GB upgrade began to stutter; I copied the software image from the 100GB drive to another disk; low-level formated the 100GB (Maxtor utilities); then copied the software image back to the 100GB. So I am running the same drive, which has had bad sectors fixed and marked (hopefully) by the utilities, but with the old software image. So far it's been pretty good. |
Originally posted by mchurchm Is there any significant difference between having a fan blow air into the unit vs. having it blow air out of the unit? I currently have mine pointed so it blows air out of the unit, and I only chose that way because I read a post somewhere that said this was preferable. Will there be any noticeable difference (noise or temperature)? Should I switch it to blow air in? |
