My HTPC Media Server is completey filled! Using a D.vine4 case every PCI slot is except the one next to the oversized pipeline heatsink on the Radeon 9600pro Ultimate videocard is used.
AGP Slot and PCI 1: Radeon 9600pro
PCI slot 2: Revolution 7.1
PCI slot 3: Hauppauge PVR 350
PCI slot 4: AccessTV HDTV card
PCI slot 5: WIreless G network card
Whats bad is that the Revolution card AND the AccessTV card both have SPIDF digtal coax output but my Denon 3300 receiver only has one AC3 SPIDF coax input!
So I decided to route the audio from SageTV and AccessTV through the PCI bus and output them out the Revolution 7.1 card analog mini outputs.
WHen using Theater Tek I use the SPIDF coax output to the Denon 3300.
Does anyone else see a problem or have a work around to switch from Theater Tek playing a DVD movie using Rev SPIDF output to using either SageTV or AccessTV playing audio out the Rev analog mini plug outputs?
After playing a TV show in AccessTV then clicking on the POWER OFF button shutting down that program I open Theater Tek to play a movie and the computer would reboot. Crashed. But when we tried to recreate that error later that night it didn't do it. BTW Im using SageTV Audio Renderer set at WAVE. That allowed me to play audio out the Rev using its Analog mini plug outputs.
I can not get SageTV to output any audio through the Rev SPIDF digital coax output. Anyone know how to do this? what settings to use?
any help is much appreciated!
