Originally posted by SportyBry
Hey guys,
I checked out the RealTraps.com WEBsite -- they make these wall panels.
Anyone here own some of these ?
They are essentially fiberglass panels mounted in a frame that has cut-
outs down the side of it. Does anyone know what the frames are made
of ? Are they plastic ? metal ? fiberglass ? Has anyone seen any kind of
framing material like this out there ?
-Sporty |
Your last question would lead one to believe you are considering making them yourself. If you do then this recent
DIY Acoustic Panels thread may help. If you are really considering getting theirs then just call them up and ask them.
OT: I come to this forum on and off suspiciously during the times I'm heavily into building my HT. It has been more than interesting to see trends in people, post and suggestions. Ethan's post are always very interesting and seem to be genuinely helpful and relevant to the thread and not geared toward pushing his product directly. Interesting are the "mass stops bass" remarks and rebuttals. Seems your goal of stopping the bass inside or outside your theater is the real question. Most want to stop it outside and then figure out how to control it inside...which is where realtraps come in.
Pretty cool solution but most probably wouldn't use them for aesthetics reasons. In general the people around here seem to care about the look of their theater almost (wrong word) as much as it's technical ability to reproduce the movie as the director intended it to be seen and heard. Myself included.
(Terry's comments are also quite good and I'm considering his service.)
Sorry for the OT just something I've thought about for a while...
I'm curious about your questions as well as I may very well add traps IF my room turns out to need them. Seems like they can always be covered with matching wall material to make them blend in. Bass never seems to care much about sound transparency of material (ie. GOM or sheetrock).
