I just ordered a Delta 410 for my HTPC and a new 5x125w power amp. After some reading here at the forum I got the idea to build my own volume wheel for controlling the master volume.
Have anyone tried anything like this?
I have seen many case modes using a wheel for controlling the fan speed, but this is probably a little more complicated. What I need is first a wheel and then some device sending commands to a serial port and witch is read by girder plug-in.
Does anyone know how to build such a device which reads the movement of a wheel and then sends some signal. Maybe a variable resistor could be used and something to read the changes in the power on the other side?
That solution seams pretty complicated and expensive maybe there is a cheaper one.
