Anyone using a 32 inch lcd in their living room?
1854 Views 20 Replies 13 Participants Last post by  andyd2k
I was looking at LCDs today. Thinking about going with the Samsung. Looks fine for my room now but I'm concerned it's not going to be big enough when I move out next summer (to probably a studio). Just wondering if the size would be big enough for a living room. Looks ok to me standing at a distance in the store but thats just for 2 minutes. Wondering what your experience has been.
I'm guessing the distance in a living room I end up with would be around 8 feet from sofa to TV. Something like that.
Status
Not open for further replies.
1 - 20 of 21 Posts
I sit about 7.5 feet from my 32" XBR Sony LCD and I think it's fine. One thing to remember is that unless the larger set has more pixels than the 32" version, you'll get a softer picture. For most LCD tv's, the 32" size is ideal for clarity. Larger sets that are 1080p should be fine too.
Ok cool. Thanks for the info. I may just get that 32 inch then when the bonus comes in :)
I just moved a 32 inch Sharp out of my bedroom into my home office (replaced by a 37inch) My main set is 55 inches. I would think 32 inches is to small for a living room. But if you do get that the prices will be lower next year when you're ready for a 42 or 50 or bigger.
I use a 32 inch LCD in my Master Bedroom at about 13 feet away and its okay. It really depends on your preference - I wanted a "fill-in" tv for the bedroom (e.g., wife for soaps) but for my home theater, it had to be fairly large but not too large so that I would have to pan my head left and right to see the entire screen. I would go larger if you are sitting 10 or more feet away.
In many ways it's about personal preference and in my case, the wife. Our living room dicates a samller TV anyway and even my friend who is a big is better guy says 32" is what we need. And doing the math, at 8 feet you are right in the range for a 32" TV for the "optimum" viewing according to the "experts". Big is nice but unless I have a dedicated media room I personally wouldn't want something so big as to dominate the whole room.
Before you settle on the Samsung, do yourself a favor and do some research in this forum. There are other LCD's that rate a bit better. Take a look at the 32" Panasonic and Toshiba sets. They should be priced comparably with the Samsung. The Panasonic will allow you to control the backlight yourself and give you more control over the picture. The Samsung has DNIe(Digital natural image engine). Most of the time it does look great but you will get artifacts. I started with Samsung myself, but "clayface" on standard cable drove me batty. Also, there's false contouring issues with even dvds and HD shows. If I were you, ask to see some standard signals on the display tvs. Not just hi-def demo material. All of the LCD's will look pretty good showing hi-def. Where they fall down is on standard material. The thing that I like about the XBR is that non-hi-def cable looks fairly natural. The XBR is also the most expensive LCD. If I could do it all over again, I would have investigated the Toshiba and Panasonic models. The price has really been dropping for those brands lately...
See less See more
Lazerfan, I'm curious what you think about the new non XBR SONY LCD's like Sony KLV-S32a10 (you mention Panasonic, Toshiba and Sony XBR as decent LCDs). As previously posted, I am having some picture quality issues on non hi-def (and hi-def) material. Thanks.
I originally had two models in the running - the 32XBR1 and the 32HP95, and decided on the latter. First and foremost, my main reasoning for the two sets was they were the only two 32" with CableCard that I had to select from (Sharp, Samsung, Westinghouse, JVC, did not have it in the 32") and it was a nice feature to have. Also wanted PC input, along with HDMI, and both of these sets had it. It's been a fantastic set. My DVD player is connected HDMI (Denon DVD-1920) and the picture is really nice. I'm not going to get into the finer detaisl of picture quality and stuff, but I'll say I like the set, and do not regret NOT spending another 600$ and getting the Sony for an extra component input.
As far as SD goes, it's SD, and nothing more. It looks good on this particular set, but the only problem I'm running into I think is what's in my lines. It's almost like a banding effect, where there's horizontal lines scrolling up or down the screen, and it depends on the channel for their variance and strength. Something I need to have looked at.
But overall, I like the set a lot.
See less See more
I have a 32" Panasonic TC-32LX50 for the livingroom, and we sit about 5.5 to 6.5 feet away from it. I would love to have gone with a 37" but the only one that would fit is the Hitachi, and that would be a tight fit for the ECT. The 32" is really nice for our size of LR, maybe with our next set will go with a 42".
I just got a Dell W3201C, I can not hang anything on the walls (apartment issues) and my entertainment center was 32" wide. I went to all the big box stores as well as some smaller places looking for the widest screen that could fit within 32 inches and was amazed at even 26" flatpanels being over 36" wide with their speakers. The only ones I found was the Samsung and the Dell at 31.01" with the speaker removed (Samsung just fit with the speakers on the bottom, I don't remember the size). Our other choice was a CRT but they were over 100lbs AND max size was 27".
The couch is about 8 feet from screen and my usual spot (when not required to sit on the couch with signficant other) is on the love seat 6.5ft away but on the side at an angle.
We both have no issues watching it from out prospective seats and are very happy with our purchase (so far, two weeks but not much viewing time because of the holidays).
if you are getting a Sony, make sure it has the Wega Engine feature. Otherwise they forgot to put in a good image processor. :eek: ie) ...XBR...
I'm looking at a 32" for our living room too, and in my opinion it should be plenty big enough. SD material not stretched on a 32" 16 by 9 set will be the same size about as on a traditional 4 by 3 27" set. I don't really get how some people have such huge screens, I start to feel ill watching a set that I have to pan to see all of it.
I live in a studio apartment as well and picked up a 32-inch JVC LCD about 2 years ago. It has met my needs very nicely and seems to be a good size.
If you don't mind paying a bit more, I think a 37 or 40 inch could be good as well - just keep in mind how big studio apartments are. Mine is about 575 sq feet, and I can sit, at most, about 4-5 feet away from my TV. I could increase that, but I wouldn't really have any room for a desk, bed etc. (i.e. - the whole apartment would be nothing but a living room).
On the other hand, if you move into a 1-bedroom apartment instead of a studio, you'd have a "proper" living room and much more space for an AV setup.
I went with the XBR versus the non-XBR, because of two factors. First, the XBR is comprised of 8 panels versus 4 panels in the non-XBR. This means that from an angle, you get a better picture. Less "fade out."
Also, the XBR has a wide color gamut backlight. The "color wide" feature really does give you more CRT tube-like colors. From what I've read, it basically puts the color decoder in proper alignment.
I think it probably sounds odd that the thing I like most about the XBR is the fact that it is CRT tube-like!
I find basic analog cable and digital cable very watchable. Worse case scenario- on the lower analog channels the picture is a touch grainy. But, the contrast is very good and the colors do not suffer from "clay face".
That was enough for me. I did start out with Samsung. A basic model, then the flagship 329D model. Clayface drove me nuts, and I was lucky enough to be able to do one Final swap up to the XBR. I regret the big dollar I spent, but the quality is there to be sure.
See less See more
A 32" lcd is pretty much a 27" 4:3 image (give or take a half inch) and a solid 32" letterbox or zoomed (sports) image. If you were happy with an old 27" crt in your living room, the 32" LCD will be fine. I'd recommend stepping up to the 37" though if you can swing it ;)
What specific models are you referring to? Also, you mention XBR but is that a Sony only feature?
Looks like I should be happy with a 32 inch from all the feedback I've gotten :) I could go for something bigger but I need to keep the width below 39 inches so that it still fits in my room
See less See more
I know you're looking for an LCD, but have you ruled out the Panasonic TH-37PX50U 37" plasma? It's 38.2 inches wide and i think the picture quality would be better than a 32" or 37" LCD.
All of the Samsungs have DNIe. I tried the LN-R328 and LN-R329D. The Panasonic I refer to is the TC-32LX50. The Toshiba model number escapes me but it's the current model you'd see at Best Buy or CC. From what I understand, the 32" Toshiba is made by Toshiba. The smaller models are Chinese knock-offs.
Yes, the features I mentioned for the XBR may be XBR only. Sharp may have that special backlight on their newest models, but I'm not sure about that. I know the non-XBR Sony does not have the advanced color-wide feature.
What I advise is buy the tv from a vendor with a liberal return policy. Check it out and if there's issues that annoy you, then swap it for another name brand.
This forum is full of good info about the various models. Do a search under "DNIe" to see what the other users have to say about Samsung tvs before you buy.
See less See more
I'm just concerned about burn in. I think I rather stick with LCDs for now
1 - 20 of 21 Posts
Status
