Hi,
I have an old Denon 5700 receiver with which I am trying to use the Dune Smart D1. I've tried every setting I can think of on the receiver and the Dune to just get 5.1 channel audio on the receiver using the S/PDIF connector from the Dune (PCM and bitstream, 48kHz and 96kHz from the Dune). However, audio only comes through as Direct 2ch on the receiver. I have some lip sync issues in this configuration as well.
Looking at the Denon manual I believe I may be running up against the limits of the old receiver.
I'm wondering if any of you have been successful in using the S/PDIF connector for multichannel audio output to an older receiver and have tips you can share in the event I'm missing something on the Dune...or the receiver.
