Status
Not open for further replies.
1 - 6 of 6 Posts
I have one. The biggest trick I've had to find was to set the Harmony to leave the cable box on all the time (I had to email support there to find the right option). If you don't have a cable box it wouldn't be an issue. Admittedly, I don't use the harmony much while watching Replay, but I use it for switching between replay, direct from the cable box (including HD), HD OTA receiver, DVD, etc.
I'm using Harmony with 4000. I did extensive XML setup - recreated menu completely. I could e-mail my files to you but I'm not sure you can use them "as is" without getting into XML.
As far as power goes, I don't have that problem for some reason. Maybe it's because my receiver connected to replay using serial port? The power always stays on.
Discussion Starter · #4 ·
Thanks guy's!
I found this:
SimpleModifier
Activity
Select your activity
USERCONFIGURATORID
97646
Device
Select your device
USERDEVICEID
42538
Mode
Select the name of your mode
NEWMENUSPECIFIER
ModeMagic
EventName
EVENT
ButtonClick_NumberStar
%Activity.Name%
%EventName%
SsNavigator
SetMenu %Activity.Type%_%Activity.Name%_ModeMagic
%Activity.Name%
ButtonClick_Guide
SsInfrared
SendInfrared %Device.Name%_ChannelGuide_Press
%Activity.Name%
ButtonClick_Stop
SsInfrared
SendInfrared %Device.Name%_Stop_Press
%Activity.Name%
ButtonClick_FrameAdvance
SsInfrared
SendInfrared %Device.Name%_DirectionRight_Press
%Activity.Type%_%Activity.Name%_%Mode%
Text Custom_Thick_8
Magic Mode:
ButtonClick_MenuSelect
SsInfrared
SendInfrared %Device.Name%_Select_Press
ButtonClick_MenuCancel
SsInfrared
SendInfrared %Device.Name%_Exit_Press
ButtonClick_MenuUp
SsInfrared
SendInfrared %Device.Name%_DirectionUp_Press
ButtonClick_MenuDown
SsInfrared
SendInfrared %Device.Name%_DirectionDown_Press
ButtonClick_Zap
SsInfrared
SendInfrared %Device.Name%_Commercial Adv_Press
ButtonClick_Help
SsInfrared
SendInfrared %Device.Name%_Menu_Press
%EventName%
SsNavigator
SetMenu %Activity.Type%_%Activity.Name%_ModeNavigate
20030306 005750
But I seem to be hitting a wall when bringing it in the remote, aka website configurator
The full article is here:
http://www.remotecentral.com/cgi-bin...thread.cgi?440
I'm not sure what you're doing but you cannot simply put the above code as it is. If you look at the beginning, you'll see phrases: "Select your activity", "Select your device", etc. What that means is that you have to replace those section with your own information. If you don't understand how the process works you should learn more about Harmony XML structure from tech support and documentation. Alternatively, you can do pretty much any setup without using XML.
1 - 6 of 6 Posts
Status
