1 - 8 of 8 Posts
Banned
Thinking about a diy home security system. There's a lot to chose from. I'm wondering if anyone can give me their experiences with these. I have a 2400 sq foot home and cats. I feel that motion detectors could be problematic. I don't have the house prewired at doors and window locations so wireless would be easier, but I don't want to mess with it if its not going to work very well.
Any thoughts?
I've used 2 different wireless security systems over the last 8 years. Both have worked well for me. One was in house a little smaller than yours (2300 square feet) on two floors. I had a motion sensor for the main floor and door sensors on all entry doors. It worked fine. I replace batteries in sensors once every couple of years and that's it. I don't have pets, but the motion sensor I had was supposed to be pet friendly. The other house is substantially bigger and has 2 floors and a basement. I have motion detectors on two of the floors and entry sensors again. I have my systems professionally monitored by a service and transmit alarm signals via the Internet, but I could use them without monitoring.
The first system I had was an old GE Simon .
The current system I use is a Visonic PowerMax Complete
There are others to choose from and newer stuff out there. They have worked well for me. I've had 2 false alarms over those 8 years. One was due to a malfunctioning sensor that I replaced and the other due to a low battery on a sensor. Visonic had sufficient sensors types and remote communication devices that met my needs.
Good luck!
If you have cats I wouldn't recommend even pet immune motion detectors. They work ok for dogs but because cats tend to move vertical, as in jumping on things, even a 15lb cat can trigger a 70lb pet immune motion. You're better off with glass break detectors.
I like DMP for wireless but if you're installing it yourself DMP is a dealer only product and a little harder to come by. DSC makes a good product as well. With current wireless technology I wouldn't be hesitant, you can get recessed door contacts and very small window sensors.
Also, for most systems you will still need to run a wire for the keypad and siren. This usually isn't too bad in most houses. DSC makes a wireless keypad but you need to go with their Alexor panel, DMP makes one as well but it needs local power and they're a little slow. Nit sure on GE or Ademco as it's been years since I've installed those.
Banned
Discussion Starter · #7 ·
Im kinda leaning toward a mostly wired system now, wired keypads, sirens, motion sensors and glass break sensors. My real problem is doors and windows. Fishing wires through walls thru outside walls would be a big job. That part of the attic is only a few inches high and then getting through headers does not sound fun.
I worry about false alarms with wireless but many say the door sensors work pretty good.
Do a mix of wired and wireless with Elk M1 or HAI OPII. Both have always offered wired and wireless, but Elk released a new wireless platform a couple years ago that's (reportedly) an improvement; haven't used either.
If you're set on doing this yourself, spend a couple months reading on the cocoontech.com Home Security subforum ( http://cocoontech.com/forums/ ) before spending a dime.
Both Elk and HAI offer dedicated subforums at cocoontech, somewhat hidden in the Marketplace subforum.
You'll need to read the install manual in detail before you buy - so you'll design the system correctly before buying.
1 - 8 of 8 Posts
