I should be getting my LT150 this week. For now I have a 6' breakout cable I bought for $7.50 that works great, but I need 25' or distance and switching capability for the following sources:
Progressive scan DVD
Sega Dreamcast with VGA output
Xbox with component HD out.
Maybe later -->iScan Pro or Plus set to component out
I was going to use the 6' breakout cables from the DVD and Xbox. to the switcher, a regular VGA cable from the Dreacast VGA box to the switchbox, and a high quality 25' extension VGA from the switchbox to the projector. Anyone have a similar setup? I don't want to spend $300 on the 25 foot cable. I am sure there is a good quality VGA cable available for much less. And switching is also of concern. I've only seen the cheap ones and the very expensive ones. Isn't there anything in between? Anyone see any possible problems with the proposed setup? I need cheap solutions here. Had to buy a cruise for my wife to quiet her after getting the LT150. Thanks for the help.
[This message has been edited by shahram72 (edited 09-12-2001).]
