The iScan won't exceed the quality of the xblaster (or any other decent transcoder) assuming the game is being output in progressive natively. All a transcoder does it change the color space from the one used for Component interfaces to the one used in VGA interfaces. That's why they don't do anything for non progressive games.
Those cheapo HK line doublers are just that, line doublers. They take one frame of 480i, copy each line and shift it up or down to fill the blank space in a 480p frame before outputting to VGA. All that does is make your aliasing problems (which are considerable with the PS2, IMO) worse. If you've got a 1 pixel stairstep in your 480i frame, it becomes 2 pixels tall when you ouput to VGA, a 2 pixel stairstep becomse 4, and so on. Its a very ugly thing.
The iScan (and the Viewsonic boxes and most other "scaler" type devices that offer VGA ouput) performs similar functions to DScaler to deinterlace the interlaced signal you give it. They tend to be more plug and play, and, depending on which you are talking about, they often are built with parts superior to a PCI capture card. However, they are limited to their hardwired processing capabilities (which can be considerable, especially as you spend more and more $$$ on them), whereas you can always feed DScaler more cpu cycles or the DScaler team can release a new version with improvements. That's the trade off (well, that and cost).
I'm going to doubt you'll see much improvement by switching to an iScan or a Viewsonic or even to something costing much more. The problem here is, "garbage in, garbage out". If you're going to throw considerable money after this problem, though, I would make sure to go up to the Video Processor forum and study up. Prices are coming down and quality is going up, but on the low end, there doesn't seem to be anything that can compete with a decent DScaler setup.
Good luck.
Kensai
