1 - 11 of 11 Posts
Hi guys,
I looked through some of the threads in this section but I couldn't reach a conclusion as to whether you could output TrueHD or DTS-HD MA from an HTPC; any input would be appreciated.
What do you mean output? Bitstream to your Receiver? OR Send as LPCM to your receiver?
Originally Posted by EVT /forum/post/17027245
Hi guys,
Hi guys,
To bitstream to an AVR from your HTPC you would need a separate audio card like the Xonar
Discussion Starter · #4 ·
I would prefer to be able to bitstream to my receiver; however, LPCM as long as it is lossless would be okay too. Would I be able to transmit either one or the other via HDMI?
Originally Posted by dbone1026 /forum/post/17028468
Agreed, I have the 4670. You can only do LPCM though, not bitsream
Originally Posted by therealbiglou /forum/post/17028502
What are the differences between Bitstream and LPCM?
(Learn a noob.)
Just remember that any LPCM from any Blu-ray playing software will only output 16/48. If you want truly lossless (or not downsampled) audio then you are going to have to either get the Xonar or do mkv/flac.
1 - 11 of 11 Posts
