Originally Posted by ImDiesel /forum/post/0
thanks for the input...
is the difference between the J10 and J15 only the amount of battery backup time...?
Yes
Following is a paper that I wrote a few months ago, but never posted. It will give you a better idea of real world loads. (BTW - - I have since removed my subwoofer from the UPS system just to make sure that it was not overloading the APC System, although I never saw anything that would lead me to believe that is was. Just seems like it should be........).
I have seen several questions in this forum about how to size a UPS for a home theatre system. Unfortunately, there is no easy answer and it is difficult to calculate the required UPS size needed based on the manufacturer's specification sheets, which are typically worst-case numbers.
I have a power conditioning system/UPS manufactured by APC (Model J15), which is rated at 835 Watts. I use this unit to power my entire HT system. My original intent when I ordered this unit was to have the J15 only power the TV and a few other items since, according to the specification pages, I would easily overload the J15. However, having everything powered from a single point was just too tempting not to try.
http://www.apc.com/resource/include/...m?base_sku=J15
One of the many features of this system is a built-in Watt meter that constantly shows the power being supplied by the unit to the HT system. I thought that it might be helpful to some readers if I published the results of some testing I did today.
First a list of items that are power by the J15, including the power requirements from the specifications sheets if available:
1. Samsung HL-S6188 DPL TV (230W)
2. Denon AVR-3300 Receiver (~645W)
3. DirecTV HR-20 DVR (power requirements not available)
4. Oppo 971 DVD Player (20W)
5. Sony SLV-N750 VCR (16W)
6. HSU-VTF MK2 Subwoofer (recommended outlet power: 430W)
7. RCA amplifier/splitter for OTA distribution (power unknown, but very minor)
As previously mentioned, all of these devices are connected to the J15 Power System. It would appear that the sum of all the power requirements of the devices listed above would easily overload the J15, but let's look at some real power output measurements based on several viewing scenarios.
1. Everything off (actually standby since none of these devices can be actually completely turned-off without pulling the plug): 103 Watts, 12% of rated capacity.
2. TV Only: 198 Watts, 23% of capacity
3. TV & HR-20: 302 Watts, 35% of capacity
4. Same as #3, but with the Denon Receiver turned-on at a comfortable to high listing level: 336 - 380Watts, 39 - 44% capacity. (Minimal subwoofer activity.)
5. TV, Oppo 971, and Denon Receiver while playing the famous depth-charging chapter (#15) in U571: Total peak power noted was 535 Watts, 62% of capacity. Very loud in a 6000 cubic foot room.
Obviously, these numbers can vary depending on the particular situation, especially the power needed by the subwoofer and the receiver. They also assume that the power meter in the J15 is accurate and can keep-up with fast changing loads. However, in my case, I appear to be below the rated capacity of the J15 during all viewing scenarios with plenty of headroom for expansion.
