2381 - 2400 of 2653 Posts
Premium Member
Anyone not getting atmos in Netflix? Prior to today it worked fine for me today atmos on everything else but Netflix and yes I have the highest quality Netflix.
I'm getting Atmos, but no LFE
Premium Member
It did come back for me before the update been getting base but have to turn it up a bit. Going to wait on 13.2 a bit
tvOS 13.2 Public Beta 2 (17K5068b) is now available... downloading now. No problems yet with the first beta.
I’m running 13.2 on one of my tvOS’s as well as an iOS and iPadOS. They all appear to be Siri related enhancements plus bug fixes based on the initial screens.
No. That would be a major change and would be announced via normal channels not by appearing in a beta update.
If I recall the "Match Content" features for Dynamic Range and Frame Rate were not announced but instead appeared in the 11.2 beta release so you never know, a beta might finally bring us passthrough one day. Fingers crossed.
Premium Member
Discussion Starter #2,394
Yes, the incremental improvements for Match (manual to mostly automatic) and DoVi in YCC (as well as RGB) were delivered as stealth updates. Brand new features come in (usually major) updates with appropriate documentation. But yes, you never know.
Premium Member
Discussion Starter #2,396
Where can I find infos on this topic?
I have never seen this documented -- presumably this is a lack on my part.
The Diva has an EDID HDFury calls "LG65C8 LLDV" (as opposed to DV V1) which I haven't tried to decode. When you use that EDID or the OPPO “player-led processing" the data stream is 12b YCC rather than 8b RGB.
Ah ok, that's LLDV. I can see the same with my Integral2.
Just note that on LG if you force LLDV the tv doesn't apply any DV calibration.
Since last public update my 2 x AppleTV4k are only downloading at 40mbps according to OOKLA Speedtest App, where previously they clocked 70mbps?
Anyone else noticed a dramatic reduction in network wifi speed?
No and I test everyday across my personal and business devices (wired and wireless). Try your phone or another device and see what you get?
Leon McKee
** Man of Leisure **
I just ran a test using Speedtest and registered 235 Mpbs download speed. No change from my perspective.
  • Like
Reactions: Soundizer17
