1 - 3 of 3 Posts
I connected Panasonic HTB550 Soundbar to Panasonic 65VT50. Used HDMI 2 (ARC) out on 65VT50 to connect to HTB550 HDM TVI (ARC),
I used 2-3 year old HDMI cables. They are not marked as High Speed cables. I read that ARC is supported by Display devices that support HDMI 1.4
But, it should make no difference. I am going to buy new highspeed HDMI cables.
My problem is that I donot hear any Sound from HTB550 Soundbar. Is the problem in the cables or in the TV.
Please suggest what is the problem.
If anyone has experienced similar problem, I would appreciate it if you could post howy you have solved it.
Premium Member
I ran into this some months ago on a friend's install - i seem to remember having to go into some Viera LInk or Viera Control menu and selecting a setting that returns audio back to the TV. I remember getting frustrated but i don't remember how i finally got it to work, but it was something i did in the menu.
Poke around the menu (or the E-Help manual) and see if you see anything like this.
1 - 3 of 3 Posts
