Status
Not open for further replies.
1 - 4 of 4 Posts
Other than setting front and center speakers to large, bi-amping the front 2 speakers....What other tweaks are there to make the avr300 sound even better?
According to IAR:
Basic are these: Set crossover to 90hz, Speaker impedance switch to 8ohms regardless of speaker type, Lift the ground switch unless it causes hum, Subwoofer mode to Large, Auto PLIIX selection mode.
More involved are these: Don't use the AVR for video switching run all video sources direct to display, Physically disconnect digital signals when running analog bypass, Change the powercord.
He also goes into speaker placement and analog connections to get the most out of 7.1 setup.
Discussion Starter · #3 ·
wow thanks...i just noticed this thread should go in "audio theory" section..who is IAR? a member of the forum?
Discussion Starter · #4 ·
international audio review...
1 - 4 of 4 Posts
Status
