1 - 1 of 1 Posts
I have been using powerdvd 10 for playing back BD movies through my htpc(GTX470->Pioneer VSX920). I used to set it so that powerdvd will not decode the audio and pass it as is.
How do I do the same with TMT, I dont see the option to disable the software processing the audio.Which is better let tmt decode it or pass it through to the AVR? the gtx470 can only do uncompressed pcm according to its specs.
1 - 1 of 1 Posts
