You're opening up a can-a-worms.
Overall, generally, and non-specifically speaking, a 9" CRT will output a brighter and thusly larger image. That would probably be the first obvious difference. Next would probably be the differentiation between an electro-magnetically focused beam (most 9") vs an eletrostatically focused beam (most 7"). The end result is a tighter more highly focused beam.
You can do a lot to improve on the electrostatically focused projectors, and probably get darn close to the spot beam size. The real issue is about the resolution you would like to run. If you're going to run a 480P signal, a 7" CRT will resolve all of the information just fine, and the only benefit a 9" CRT would be brightness (size of screen). Move up to 1080i and the general consensus is that most 7" CRT's will fully resolve the image... the final would be 720P and this is the hot debate. If you do a lot of electronic mods to your 7" CRT, you will be able to do 720P. 1080P (doubled 1080i) is probably not a goal the average 7" owner should think about. Yes, many of the projectors will to 1280x1024, but there is going to be a lot of line overlap, ie. not fully resolving the image. If you're not the average 7" owner, an fine role model would be KBK when he was tinkering with a 7" CRT that he had HEAVILY modified. He had touched nearly every aspect of that projector. As I recall, he said that he had achieved some sick and wrong numbers and was STILL able to discern line structure... I don't recall the number, but he was well over 1280P!
