421 - 440 of 450 Posts
since i have the bic america venturi line of speakers. would it be best to get the bic america Dv-62SIB bookshelf speakers for my front height speakers so they match ?
Probably. It's usually preferable to keep drivers as similar as possible for timbre matching. It may not be as important for surround speakers as a center channel, but still an improvement when sounds don't change just by panning around the room (important in a movie like Gravity where dialog moves all over the room).
It might be harder to tell timbre differences with things like explosions than dialog, for example. Some say Audyssey and other room correction systems sometimes help in that regard, but that's not what they were designed for.
any suggestions on how and what to use to point my front height bookshelf speakers downward so I can point them to the listener ?
thank you
I bought some studio foam wedges that angle the speakers downward a bit, but it's not a whole lot.
thank you
https://www.amazon.com/gp/product/B01KNWTPRI/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 ... good if sitting on a shelf where not a lot of angle is need
https://www.amazon.com/gp/product/B07YD58YLQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1...I use a few of these under my center speaker. Can be "carved" for a custom size. Hacksaw blade or coping saw worked fine.
https://www.amazon.com/gp/product/B000X9O8SI/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1..good for if higher up on the wall. Can modify for more of a downward angle.
awesome. thank you.
interested in number two
will it not tilt the speakers too far forward to where they could tip ?
awesome. thank you.
You can shape these any way you like. Made of a dense foam type material.
Maybe? They have a front lip to help. You could always use some of this on the bottom of the speaker. Easily removable and holds great. https://www.amazon.com/Bostik-Mastic-Adhesive-approx-801103/dp/B00I42EOJE/ref=sr_1_3?crid=37UF3IK6AXL3Y&dchild=1&keywords=blue+tack&qid=1587391458&sprefix=blue+t,aps,319&sr=8-3
decided to go with this
https://www.amazon.com/Audioengine-Desktop-Speaker-Stands-Pair/dp/B005STCILC/ref=cm_cr_arp_d_product_top?ie=UTF8
going to put some blutak on the speakers attached to the stand and on the stand attached to the top entertainment shelf
does that sound about right ?
That's more or less what I'm using for my front height speakers. I don't use any blutak, though. I also changed the PSB tweeters on my Image series speakers here to a fabric tweeter that seems to have much better off-axis response for the front height and side heights that are less aimable. No timbre anomalies I can detect and the response sounds pretty even with the Helicopter flying around now (rear CS500s are fully aimable and were perhaps just a tad brighter so they now match quite well, IMO).
maybe i will try without blutack first
Hi all. Been reading this thread for a while now.
I had front and rear heights. I've since moved the front heights to the top front position, but on the side wall aimed at mlp from near the roof/wall join.
Has anyone else done this. What setting are you using in the avr. I'm currently using a marantz sr6013 and set to top front and read height.
Are Front Height Speakers OK to use as Atmos speakers?
Tried to search without luck.
Although not ideal or recommended, can Front Height speakers be used as Atmos speakers when other optional are not available?
From The Dolby Atmos Home Theater Installation Guide about Front height mounted speakers: Most AVRs will support the use of front height (Dolby® Pro Logic® IIz) mounted speakers with Dolby Atmos playback; however, we recommend the use of either overhead or Dolby Atmos enabled speakers to create the most lifelike and enveloping audio experience. Front height speakers may be used in conjunction with overhead speakers in larger room installations that can support a greater number of overhead/height outputs.
With that, will an AV Receiver setup with Front Height speakers support them using Dolby Atmos? Will sound come out of them?
According to the above, it seems possible but wanted to ask anyone with an actual Atmos receiver. Any help or information would be appreciated.
I have front height in wall Dolby Atmos speakers and one set in the ceiling because I had the fronts setup for dolby prologllz. I like the sound of it.
I have a processor capable of Atmos but currently running a 5.1 speaker layout. I have an extra set of bookshelf speakers that are a very close match to the current speakers, same manufacturer updated model. What do you all think about front heights above the main L/R For a 5.1.2 or I could just add rear surrounds and end up 7.1? With the vaulted ceilings placement is a challenge but would like to have the immersive experience...suggestions? Thx!
3024714
Had a question on positioning. Planning to get some KEF Q50a's as front heights to use as atmos. They'll be on a shelf high up near the ceiling (built in TV cabinet in the living room). My question is, are front heights used as atmos supposed to go "above" the L-R speakers, or since they're heights, can they be spaced a bit closer to each other. Given my room setup, my L-R will have about 15 feet of distance between them, so not sure if the heights must also have this, or if they's supposed to be closer to the TV/each other.
Is there a general consensus yet regarding using just front heights for Atmos duty (if one can only pull off a 5.1.2 configuration)?
Does it work well? Should they be hooked up on the AVR as FHR/FHL or would it be better hooking them up at a different terminal?
I think most people would suggest directly overhead or just in front of the main listening position overhead (even if mounted high on the side walls instead of the ceiling) would probably be the best location for only having 2 overheads as that puts sounds in a place nowhere near the 5.1 locations (i.e. more noticeable). However, two front heights are certainly better than none and if you ever expand to 4 overheads, you can leave them where they are and just add the rear speakers. Most AVRs will tell you where to connect it for only 2 overheads.
