Always? No. Placement is very important.
poorly located and aligned multiple subs can and likely will be worse than a well calibrated/located/aligned single sub.Or can you actually have worse bass response in a room by having too many? What about in small rooms? Would more always be better for bass response?
Not effectively. The processor, in this case, only has one channel so all 4 subs act like 1 sub in the eyes of the processor. The subs need to be setup to work well with one another and THEN presented to the processor as a single, well-performing sub.Thanks.
Say you have 4 passive subwoofers (2 in the front and 2 in the rear) connected to a single 4-channel amp. The amp is connected to the subwoofer/LFE out on the processor. Will the processor be able to calibrate the subwoofers effectively while only seeing all 4 subwoofers as one subwoofer?
You will likely need some method of delaying either the rear (or front) subs (or flipping the phase on front or rear)Thanks.
Nope.... Say you have 4 passive subwoofers ... connected to a single 4-channel amp. The amp is connected to the subwoofer/LFE out on the processor. Will the processor be able to calibrate the subwoofers effectively while only seeing all 4 subwoofers as one subwoofer?
To guarantee improved results, you'll need to be able control each sub independently from the others. This means each sub needs its own amp channel and the amp would need a dedicated input for each sub channel. Then upstream of that you need a DSP of some kind to set the delay for each sub channel independently.Thanks.
Lol it’s good to know that 5000 subwoofers in a room eliminate all nulls 😂Your question and more are answered in this "white paper". Althouth it's technical and scientific, it's written at an understandable level for most and the sections/issues are divided by the questions and key points to the left of the text.
If you read and understand this and another white paper Harmon has on line you'll get a pretty good understanding of Subs, placement, what works and what doesn't and why. Happy reading. https://www.harman.com/documents/multsubs_0.pdf
More or less same story for me. I will also add for sound quality combined frequency response does not tell the whole story.Two subs from a receiver with two independent sub outputs was better than 1 sub in my room. 4 is even better - but required a Mini DSP HD to really implement properly.
A caveat with the Harmon work is that is it done on the basis of a symmetrical room. If you have an asymmetrical room or a "room" that is part of a larger open/semi-open floor plan, it tends to complicate things further. Not to say that the work isn't valid or even still quite valuable for such rooms, but just want to point that out to any interested parties.Your question and more are answered in this "white paper". Althouth it's technical and scientific, it's written at an understandable level for most and the sections/issues are divided by the questions and key points to the left of the text.
Bass traps and acoustic treatments also helped a lot !More or less same story for me. I will also add for sound quality combined frequency response does not tell the whole story.
If one chosen location introduces ringing or localization in a key area that's what you'll hear, even if the combined response isn't bad and there's no issue with the other subs. The "weak link in the chain" will bring things down.
For 4 subs a minidsp or similar is a must if sound quality is a priority IMO.
Here's a decent article on placement in a non symetrical room. Subwoofer Placement In Non-Rectangular RoomsA caveat with the Harmon work is that is it done on the basis of a symmetrical room. If you have an asymmetrical room or a "room" that is part of a larger open/semi-open floor plan, it tends to complicate things further. Not to say that the work isn't valid or even still quite valuable for such rooms, but just want to point that out to any interested parties.
