1 - 16 of 16 Posts
· Registered
If I press pause and walk right up to my plasma TV, I can see pixels sparkling on the display instead of a completely static image. Is this normal or is there something wrong with my TV or maybe my reception? If it's not normal, is there anything I can do to fix it? Although I can't see the sparkling pixels at my normal viewing distance of 10-11 feet, I'm worried that they may be reducing my picture quality.
· Registered
Originally Posted by NetSpiker  /t/1522773/are-plasma-tvs-supposed-to-have-sparkling-pixels#post_24488790
it's normal for All plasma TVs
· Registered
Discussion Starter · #4 ·
Originally Posted by StinDaWg  /t/1522773/are-plasma-tvs-supposed-to-have-sparkling-pixels#post_24488826
Yes, and if you see them, it means you need to turn the brightness down on an all black screen until they go away.
I don't understand. Why an all black screen?
· Registered
Originally Posted by RWetmore  /t/1522773/are-plasma-tvs-supposed-to-have-sparkling-pixels#post_24491135
You definitely want it at zero.
Originally Posted by NetSpiker  /t/1522773/are-plasma-tvs-supposed-to-have-sparkling-pixels#post_24491057
My Sharpness is set to 10.
Did you use the Spears and Munsil pattern? 0 was what mine came to.
You wont know that unless you have a black pluge pattern. Or you're crushing blacks.
Originally Posted by KONICA TECH  /t/1522773/are-plasma-tvs-supposed-to-have-sparkling-pixels#post_24491152
yes
What TV? Since when was Plasma as smooth as LCD...
· Registered
Originally Posted by xvfx  /t/1522773/are-plasma-tvs-supposed-to-have-sparkling-pixels#post_24491176
I own a Samsung 8500, what do you own? And I was not disagreeing with excessive levels causing sparklies, I was just adding that a defective HDMI could be the cause. What did you add?  If I did I would get rid of the set.
· Registered
Discussion Starter · #15 ·
Changing the Sharpness to 0 didn't do anything. I've noticed that the sparkling is more apparent in the boundaries between different colors. Maybe sparkling pixels is how plasma TVs produce greater color variation.
I haven't used any Spears and Munsil patterns or any other calibration method yet.
1 - 16 of 16 Posts
