1 - 20 of 69 Posts
Discussion Starter #1
If a choice between towers or large monitor speakers .. are towers the way to go if you can fit them even if you are running subs ? Because with subs you would be running the towers are small right ?
Some say yes, some say no.
I have a system with towers and another with stand mount speakers and am happy with both.
I got towers as in that room the cats knocked over the stand mount speakers.
Space size? Budget? Seating distance?
You "might" be able to get a very minute more amount of volume out of towers compared to bookshelves/monitors when using with subwoofers.
IMO, there are 3 main things to consider when evaluating them:
  1. Price (you get more bang for the buck with the smaller speakers)
  2. Aesthetics (it is hard to deny a nice tower looks awesome in every room)
  3. Room functionality. The smaller speakers can be mounted off the floor freeing up even more space that can be used for optimum subwoofer positioning/tuning. There is some value to this if you want perfection from your subs.
To answer your last question, yes configure your towers as small to allow the Subs to appropriately handle the frequencies that they are designed to handle.
  • Like
Reactions: nathan_h
Discussion Starter #6
about 2900 cubic feet
Seating distance is about 8-9' .. listen levels around -10db
Im just wondering if you run your towers as small are the extra woofers doing anything if you are cross'd at 80
Towers mainly for music listening in 2.0 otherwise for HT they are simply a visual/aesthetic preference compared to bookshelves with sub(s), unless you are a volume freak then they usually will get louder.
  • Like
Reactions: derekmoore
Extra woofers don’t have to move as much compared to a single 1. So less distortion.
You also have increased power handling and output.
Since they reach lower you are guaranteed to have a better crossover from mains to sub.
Harder to knock over. Generally towers cost just as much as speakers+stands but instead you are paying for 100% speaker.
Strictly music? Towers at Full range and add sealed subs later on.
Music/movies?
Bookshelfs/towers and ported subs. Towers should be ran at small crossover should be 80hz LFE 120hz
Sounds to me like you'd be a perfect candidate for dual woofer bookshelves, e.g. Ascend 340SE or Chane A2.4, with a good sub or two. Especially if HT is 50% or more of your usage.
75" Samsung Q80R QLED, Denon AVR3300, Revel F36, C25, W263, FV15HP x 2, ATV4K, Sony Blu Ray, Harmony
Most definitely. A small single woofer tends to distort quite fast in the 80-300 Hz range, so having 2-3 woofers covering this range makes the speaker more capable with lower distortion and better sound quality. If you never want to listen at higher than conversational levels it of course won't matter in terms of power handling, distortion, etc. Other factors come in to play for some such as aesthetics, as to whether you like how small speakers balancing on stands look compared to a normal tower speaker etc.
-10 dB requires 95 dB *peaks* at the listening position...most bookshelves will have a fair bit of distortion coming into play at that level. For example, using a small inexpensive but well designed and well regarded speaker of above average sensitive, the Ascend CBM-170 bookshelf speaker is hitting about 5% distortion from the single small woofer at 95 dB at 2m. Distortion at your listening distance at that level would be higher, since room and boundary gain is not going to increase sensitivity over the frequency range in which the woofer is distorting.
To further this, anyone who is optimizing spekaers for sound quality will be adding eq to the speaker below 300 Hz. At bare minimum, room eq will likely add 3-6 dB of eq, which doubles or quadruples the amount of power being dumped into the speaker. This will skyrocket distortion. Yep, things will sound intolerably loud from this.
A tower speaker will play quite a bit louder before this distortion sets in. Happens at lower levels than people realize.
Bookshelves are fine for some, but towers hold very clear advantages in many regards even when crossed to subs.
Here is another much more expensive, very well designed, highly regarded bookshelf speaker at 90 dB @ 2m. 10% distortion at 100 Hz:( the steeply rising lower black line is distortion level)
Again, increase output to account for distance greater than 2m, eq, etc.
+1 put me down for this. This tends to be an unpopular opinion around here, but it's one I share. Mostly reiterating, but I like/prefer towers because:
1) They do tend to play louder with more ease (higher rated sensitivity)
2) They do tend to play deeper, giving you more flexability with setting your crossover into your subwoofer, and allowing them to drive down into and through that crossover point with more authority at high listening levels.
3) I don't hate Room EQ the way some purists (mostly on other boards) do, but sometimes I do like to turn EQ off anyway... and I like the closer-to-full-range sound I get from Towers while in Direct mode.
4) I like how they are generally sturdier and harder to accidentally tip (I've got small kids).
I do think the price difference between the tower and the bookshelf tends to be a little bit more than just a good sturdy (sand-filled) stand, but I agree with the point none-the-less. You chew up a good chunk of your "savings" by buying the (good/sturdy) stands. And stands aren't speakers and don't make music. And I'd rather spend my $$$ on speakers than stands.
Discussion Starter #13 (Edited)
Sorry I thought I said this is for 100% HT .. no music
The speakers im trying to decide is between a full tower or a large monitor that has dual 8" woofers in it. So the towers have 4 8" woofers and the monitors have dual 8".
Here are the speakers ... they are arendal 1723 towers vs monitors
monitors on the matching stand
Based on that, I would maybe go with towers in that case, but also have a sub if you don't already have one (or two).
Budget?
i discovered between b&w towers 702 S2 and the 'monitor like' bookshelves of the same series 705 S2, that the latter paired to a sub were better sounding speakers. But there is no rule of thumb, it can vary between manufacturer and models. If you have specific tower and monitor models in mind, go demo and compare them.
big room, loud listening, etc argues for towers. Budget restrictions (and bang for the buck) and placement issue, if floor space is ahrd to come by, argue for bookshelves. Both argue for subwoofers, especially for 100%HT.
Your situation cries out for a really efficient speaker...and likely the tower is the most efficient of the two you are considering, but I haven't looked at the stats....
In your case, the design of those specific towers/stand mounts certainly takes a lot of the aesthetic issue out of the equation imo....they both pretty much have the appearance of tower speakers, vs the typical bookshelf balanced precariously on a thin little stand.
So in your case it will come down to what should be lower extension for possible improved blending with subs due to a deeper response and shallower roll off below crossover, and increased output capabilty before distortion sets in. In either case, they should be crossed to a good pair of subs. Nice looking speakers. Towers are 3 dB higher sensitivity, so require half the power to play at the same loudness.
I've never looked at Adrenal speakers before, they look REALLY nice....lots of nice info on their site too. I'm impressed.
You're only sitting 8-9ft away, you said.
If you really like it loud, PSA MT-110 would be fine, single 10" woofer. At most, MT-210 with dual 10" woofers or the tower version, MT-210T.
Unless you simply prefer the looks of the other 2 options.
  • Like
Reactions: rhelliott2
I prefer towers. In my last setup I found that crossing over the speakers at 60 Hz was preferable for the impact that I was looking for. That was with a sub of course.
Also note the crossover is not a brick wall; frequencies above and below the crossover frequency do not instantly drop to 0 amplitude. At 80 Hz and 12 dB/oct, typical for AVRs (or was, I have not looked recently), the sub is about half as loud at 160 Hz, and the mains about half as loud at 40 Hz. That means having some margin in the mains (and sub) to cover those extra frequencies can help the sound. I prefer to set the crossover an octave above the -3 dB frequency of the main speakers, or at least half an octave. That means I prefer mains with sufficient bass capability to provide good sound well below the crossover, whether towers or not. Towers usually provide lower response and higher sensitivity so deliver more bass with less power than smaller monitors.
IME/IMO/FWIWFM/YMMV/etc. - Don
  • Like
Reactions: psuKinger
1 - 20 of 69 Posts
