I'm just curious to know what everyone's opinion is on spacers.
I recently bought an LG 60" PC1D that weights 135lbs. I intend to use a Sanus VMPL flush mount (which is rated for 160lbs), but I want to use the supplied plastic spacers to push the TV out an additional inch from the wall. The spacers would be applied to the screws that fasten the mount to the TV itself.
I know I am sacrificing a flush appearence, but I really don't want to have to lift the TV everytime I need to go behind the TV to adjust or attach a cable.
Anyway, my worry is, since the TV is so heavy, is it risky to use a spacer to push the TV out from the mount's intended surface? Wouldn't it introduce some fairly strong shearing forces on the screw?
