I personally am a Yamaha fan. It bothers me to see them accused of lying. I wanted to address a few points in this thread.
First off, I feel total system power commonly used in HITB ads is misleading. Cleary a 900W system does not produce 900watts. Yamaha does this same sort of rating. FTC is not doing their job by putting a stop to this. Why would a fairly respected company like Yamaha follow this misleading practice? I guess they need to compete with the other HITB makers. On the bright side, if a consumer is looking at only HITB systems they should not be too off base comparing total system power ratings wrong as they are.
As for AVRs, Yamaha is totally within their rights to say 100x5, or whatever. The FTC appears to only require one channel driven for multi-channel amps. And almost every manufacture does it.
Not only is it within acceptable FTC practices, it's not invalid to say 100x5 for an AVR. It's commonly accepted that movie soundtracks don't drive all channels at the same level very often.
I for one don't like the way the FTC is going. They are weakening the rules rather than strengthing them. When reading some FTC documents on proposed rules changes it seemed they were catering to the manufacturers and not the consumers.
I would like to see these changes made:
* Companies can't claim total system power numbers based on one channel driven
* Companies should explicity make it clear that ratings are one channel driven where applicable; something like 100x5 (One channel driven)
Link
Changes to the FTC amp rating rules
Link
