As per a suggestion, I'm opening a poll.
Basically, if you are experiencing the annoying "skip" or "stutter" problem on your HD-A1, please let us all know.
Effectively:
You'll be watching a movie and all of a sudden, it seems to pause. Then, it resumes and briefly plays at a rate faster than 1x (looks like it's in fast forward). Then, it goes back to normal playback. Sometimes, after this happens, the audio and video are out of sync and require you to pause/unpause the film or move forward/back a chapter to restore synchronization.
If you ARE having this problem, please report what firmware version you are using, and if you are using HDMI vs. Component and if you are using the analog outputs vs. optical.
Finally, is this disc you were playing new or a rental (Netflix, etc) with some scratches?
A lot of people are reporting this problem with brand new disks and I'm curious to see:
1) How widespread it is.
2) Are there any common factors.
Please, no fanboyism. If it's happened to you, vote as such.
This problem is annoying a lot people and pretending the problem doesn't exist so HD-DVD doesn't look bad is just silliness.
Effectively:
