As someone who still has a large number of non-anamorphic discs, some form of aspect ratio control/zooming of windowboxed images within a 16:9 display is a vital feature on any new deck I pick up these days. The UK Toshiba SD-520 (equivalent model to the US SD-3800) performed the task near perfectly via. the Zoran Vaddis V, but was poorly implemented and almost hidden as a standard zoom function. Shame as the offset in picture quality was marginal when zooming/upscaling a letterboxed DVD. I'm currently running a Panasonic S75 (S55 in the States, I believe) which options the feature much more accurately in the GUI. But, after recently increasing the display size, the glaringly apparent pixilation and excessive softness in the zoomed image isn't pretty to say the least. I'm also presently running a Liteon 2001 which scales/zooms to almost the quality level of the SD-520 using the Sigma chipset. But again, the feature is pathetically implemented as discussed in many a D1 thread. Another personally essential aspect of the zooming feature overall is keeping subtitles/overlays onscreen. Both the aforementioned players pull this off, but the latter doesn't. So, top and bottom is I'm on the hunt for a player which accommodates the plus points mentioned from the 3 discussed decks above into one unit. Unfortunately, the only option within my limited budget that seems to offer this feature appears to be the Denon DVD-700 (DVD-910). Anyone had any experience using this particularly players zoom/ratio control function and could kindly comment on its performance? I suspect it'll be a matter of the player reformatting a 4:3 image into the centre of a 16:9 display, then scaling up all 4 corners to the required size using the zoom function. Any comments greatly appreciated...
