UPDATED 1/26/09 Added Customizable hotkey support for over 35 functions
and bug fixes.
Global checkbox options now have persistence.
Support for dual monitors, when the application is moved past 60% on the second monitor the blanking then moves to the second monitor. Only works on side by side monitor setups.
Was bored on this cold weekend and decided to put together a little application to control aspect ratios for software based DVD & Blu-ray players. It’s pretty basic right now but does seem to work. Any feedback would be appreciated.
Requirements: DOT.NET framework version 2.0 (XP only)
For PowerDVD make sure you have "Stretch to Fit the Screen" checked under Aspect Ratios on the PowerDVD context menu.
Start the application to control. To create a new Aspect Ratio Press "New" button select the application to control. Name your new aspect and press OK. You should then be able move the software player around on the screen using the appropriate buttons.
New Aspect Ratio
To assign a function to a hotkey press the "Hot Key" button. Select the function and the hotkey.
Assign Hotkey
View assigned hotkey press the "?" button next to close box on the main screen.
Hotkey Help
Download and unzip from this link.
Mike
and bug fixes.
New Aspect Ratio
Assign Hotkey
Hotkey Help
Mike
