1 - 3 of 3 Posts
Just wired up a new receiver (Pioneer Elite VSX-70), this is my setup:
AT&T wireless HD DVR STB (output) ------HDMI--------> (SAT/CBL input) VSX-70
VSX-70 (#1 ARC output) -------HDMI---------> (#2 ARC input) LG 60PM9700 Plasma
It appears i am only getting PCM 2 Channel audio via the U-verse STB on all channels, including HD etc.  Since this is a pioneer, in the top left hand corner next to the "HDMI" current input box on the display, I can see that out of the (9) possible speaker boxes that can be lit, only the (2) front LEFT/RIGHT little boxes are lit no matter the channel and "PCM" is displayed at all times.
I can force audio to 5.1 PLII by switching "standard surround" to PLII, but I want the input coming in to be true 5.1, not 2CH PCM to 5.1 PLII.
How can I get 5.1 from my Uverse STB to the reciever?
Also, i assume that in order to use the TV's smart apps (Netflix, mainly) and get the sound to the AVR in 5.1 or whatever, i must run an optical from the TV to the AVR as it is the TV that is generating the APP (so i must have an out from TV to AVR, not just the other way around).
TIA!
Originally Posted by Br0s  /t/1523011/at-t-u-verse-issue-with-2-channel-pcm-only-pioneer-vsx-70#post_24494794
Hi Br0s, did you set uverse stb audio menu to "Surround Sound"?
Menu > Option > Audio/Language > Digital Audio Output > Surround Sound > Save
Discussion Starter · #3 ·
Originally Posted by JChin  /t/1523011/at-t-u-verse-issue-with-2-channel-pcm-only-pioneer-vsx-70#post_24495547
I was just reading about that yesterday on some AT&T help forums, so i'll give it shot and see if works later.It appears that as of a couple of years ago the STB's now allow 5.1 to travel via HDMI instead of how they used to only allow 5.1 to travel via optical out of the STB.
I very much appreciate your detailed help, JChin. I'll report back if this works or not.
1 - 3 of 3 Posts
