OK,
I have a HTPC using ATI 9600XT AGP board driving a Sony VPLHS20 PJ thru DVI. I also have a Gefen 1:2 DVI splitter/hub to drive the 40ft+ cable length cleanly. The added advantage I have with this hub is I use the second output to loop back to a FP Monitor on top of my HTPC for debug. The native res of the PJ and FP are the same so I get to see what is going on with the PJ 1:1.
Anyway, I'm looking to change my config to run the output of the HTPC into a Component Switch. This will allow me to drive many 16:9 LCD TVs in my house...as well as the PJ. I have the ATI DVI-to-HDTV adapter but my question is.....can I put this on the output of my Gefen Hub DVI port ? I've enabled the 720P drivers (Cat6.12) and my idea is to run DVI cable from the 9600XT to the hub......then output #1 has the Adapter on it and component cable plugged in going to switch....hub output #2 would be DVI cable to FP Mon. My concern is that this adapter is not doing a D/A conversion but instead using analog from the DVI ? If so, I assume the component would still work but not the DVI back to the FP monitor ? What is this adapter really doing ? Also, if it is analog from 9600XT DVI would this pass through and the FP mon see anyway ?
Here is my hub: http://www.gefen.com/kvm/product.jsp?prod_id=2987
