Status
Not open for further replies.
1 - 3 of 3 Posts
Anyone tried this.
I have a plus piano front projector that I am trying to hook up to my ati radeon 8500le video card (dvi-d, s-video and rgb out).
When I hook up my computer by s video the bios setup screen is projected but when the computer continues to boot up the projector says that it can't find the s video signal anymore.
Any suggestions?????
thx
Did you go into Display Properites /Settings / Advanced /Displays and set TV out ON?
In any case, forget about Svideo.
You should use either the 8500's VGA out or a DVI to VGA adapter at the projectors native resolution, the difference in PQ will amaze.
In order to get "video" out of the card to the TV/projector, I believe that you have to make the TV output the primary display... YMMV.
1 - 3 of 3 Posts
Status
