Following are three pics with notes showing scoped settings with TT2 and overlay. These show the Pluge with white and reverse greyscale ramps from DVE. My system is PAL, if it matters.
Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
guess I'm a n00b, I have no idea what those 3 results mean |
Best results for IRE 7.5 displays and Overlay: Brightness at 91 (not too sensitive), Contrast -11 (fairly sensitive) (these numbers are TT video settings)-- FYI, I read a post where someone suggested B=83 and C=-10 which is pretty close to my measurements... This person has good eyes and a well calibrated display. Best settings for IRE 7.5 displays and VMR9 (After having set the ATI control panel to its default values for gamma, contrast and brightness): B=17,C= -8 Best results for IRE 0 displays and overlay : Brightness at -8 (from -9 to -7 is pretty good), and Contrast at +2 (these numbers are TT video settings) Best results for IRE 0 displays and VMR9 : Brightness at -9 and Contrast at +4 -- thus very similar results to the overlay (probably within the error range for these types of measurements). |
Originally posted by pasey25 gazzadazza, what is the effect on the others if your display requires a bump of gamma by one step? |
Originally posted by Rich L Do you suggest we change our TT2 to these settings and then calibrate our TV using VE or Avia? |
Originally posted by kromkamp To compare, here is another user's (Eiffel) scoped Radeon settings from the TT forum: Interesting that gazzagazza's 'full range' settings correspond with these settings for a 7.5IRE display. Thats backwards, unless I'm not wrapping my brain around this (and this is one issue I frequently lose touch with! |
Originally posted by mikemav I have an ATI 9600 (non pro.) Using the VGA output. I want to optimize the video settings on the ATI control panel and may not end up using TheaterTek to play back DVDs.... but for now am looking for a starting point to see if anyone has scoped the ATI 9600 or similar/ Catalyst drivers outside of TheaterTek. |
