Hi guys, need your help and advice.
I have Xfinity internet, no cable. My router is in a room with only one incoming coax. My OTA antenna is routed to the other rooms for tv in my closet which contains the main Xfinity feed for internet which of course only goes to the room with the router. The other feeds are connected to the antenna.
Basically, I want the room with the router to also have access to the antenna feed.
Is there a way to feed both to that room on one cable? Maybe a diplexer to split the signals, one to the router, the other to my HDHomerun which can then run with a direct connection to my router.
The reason is I am have problems with the HDHomerun signal , and I have used both a WiFi extender and a Powerline transmitter. They both have intermittent signal loss/pixelation. When I connect the tv directly to the antenna I have no issues. I have tested this many times and same results.
When I start to see pixelation, I check the antenna signal on my phone to very signal, then I immediately change the tv input to antenna. Antenna plays solid. No pixelation. Tested numerous times.
The HDHomerun is designed to run off an Ethernet connection, and has hiccups with any substitute such as a Powerline adaptor or a WiFi extender.
Any ideas?
Len
